/ AutoCAD Architecture 2008
venz
19 Марта 2007
AutoCAD Architecture 2008 (ex-Autodesk Architectural Desktop 2007)
Серия Autodesk 2008
http://www.autodesk.com/mini-sites/buzz/en/products.htm#13
- оффсайт
http://www.autocad.ru/cgi-bin/f1/board.cgi?t=33272WO
- Обзор нового в AutoCAD Architecture 2008 на autocad.ru
ADT:
http://www.caddigest.com/subjects/adt/features.htm
http://rcd.typepad.com/rcd/2007/03/autocad_archite.html
http://rcd.typepad.com/rcd/2007/03/autocad_archite_1.html
Vista and AutoCAD:
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_and_aut.html
AutoCAD 2008:
http://www.tenlinks.com/news/PR/AUTODESK/021307_acad08.htm
http://www.tenlinks.com/news/PR/AUTODESK/021307_v2008.htm
http://www.tenlinks.com/news/PR/AUTODESK/revit/021307_2008.htm
http://heidihewett.blogs.com/my_weblog/2007/02/autocad_2008_th.html
http://heidihewett.blogs.com/my_weblog/2007/02/set_all_object_.html
http://heidihewett.blogs.com/my_weblog/2007/03/layouts_and_she.html
http://heidihewett.blogs.com/my_weblog/2007/03/layer_notificat.html
http://heidihewett.blogs.com/my_weblog/2007/02/annotation_scal.html
http://heidihewett.blogs.com/my_weblog/2007/02/tables_from_dat.html
http://heidihewett.blogs.com/my_weblog/2007/02/table_data_in_a.html
http://heidihewett.blogs.com/my_weblog/2007/02/mtext_in_autoca.html
http://heidihewett.blogs.com/my_weblog/2007/02/tables_in_autoc.html
http://heidihewett.blogs.com/my_weblog/2007/02/multileaders.html
http://heidihewett.blogs.com/my_weblog/2007/02/layer_propertie.html
http://heidihewett.blogs.com/my_weblog/2007/02/dimension_enhan.html
http://dwf.blogs.com/beyond_the_paper/2007/02/autocad_2008_ak.html
http://dwf.blogs.com/beyond_the_paper/2007/02/whats_new_in_au.html
http://knowingwhatyoudontknow.blogspot.com/2007/02/say-goodbye-to-adt.html
http://ellenfinkelstein.com/autoCAD.html#acad2008
http://lynn.blogs.com/lynn_allens_blog/2007/02/its_official_au.html
http://worldcadaccess.typepad.com/blog/2007/02/autocad_2008all.html
http://www.caddigest.com/subjects/autocad/2008.htm
http://mistressofthedorkness.blogspot.com/2007/02/news-about-autodesk-2008-products.html
http://mistressofthedorkness.blogspot.com/2007/02/autocad-2008-and-2008-line-of-products.html
http://caddmanager.com/blog/2007/02/autocad-2008-and-dgn-files.html
http://bazzacad.com/WordPress/2007/02/13/autocad2008-is-just-around-the-corner/
http://learnacad.blogspot.com/2007/02/autocad-2008-new-features.html
http://lynn.blogs.com/lynn_allens_blog/2007/02/happy_valentine.html
http://caddmanager.com/blog/2007/02/autocad-2008-inverted-xclip.html
http://cadman-do.blogspot.com/2007/02/autodesk-tells-all-day-two.html
http://through-the-interface.typepad.com/through_the_interface/2007/02/autocad_2008_ne_1.html
http://lynn.blogs.com/lynn_allens_blog/2007/02/the_autocad_200.html
http://autodesk.blogs.com/between_the_lines/2007/02/system_requirem.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_le.html
http://rcd.typepad.com/rcd/2007/02/autocad_2008_la.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_sy.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_ch.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_di.html
http://autodesk.blogs.com/between_the_lines/2007/02/some_of_my_auto.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_ne.html
http://autodesk.blogs.com/between_the_lines/2007/02/autocad_2008_co_1.html
http://autodesk.blogs.com/between_the_lines/2007/03/autocad_2008_wi.html
http://autodesk.blogs.com/between_the_lines/2007/03/autocad_2008_us.html
http://lynn.blogs.com/lynn_allens_blog/2007/02/more_autocad_20.html
http://lynn.blogs.com/lynn_allens_blog/2007/02/autocad_2008_ui.html
http://mdouglas.blogs.com/in_the_dynamic_interface/2007/02/sometimes_its_t.html
http://caddmanager.com/blog/2007/02/autocad-2008-and-layer-reconciler.html
http://rcd.typepad.com/rcd/2007/02/autocad_2008_cu.html
http://lynn.blogs.com/lynn_allens_blog/2007/02/more_autocad_20_1.html
http://jtbworld.blogspot.com/2007/02/snipping-tool-vista-killer-application.html
http://bethscadblog.blogspot.com/2007/02/automatic-dwf-publish-in-autocad-2008.html
http://jtbworld.blogspot.com/2007/02/migrate-custom-settings-in-autocad-2008.html
http://autocadder.blogspot.com/2007/02/autocad-2008-compatibility.html
http://autocadder.blogspot.com/2007/02/police-your-layers-in-autocad-2008.html
http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=407696
http://jtbworld.blogspot.com/2007/03/infocenter-search-results-in-autocad.html
видео (онлайн)
http://heidihewett.blogs.com/my_weblog/files/AutoCAD2008Videos.htm
нашу "электрическую" аудиторию думаю заинтересует поддержка точечными светильниками файлов светораспределения *.ies
Сeргей
19 Марта 2007
382
6 232
Гм про светильники - это интересно.
venz
15 Мая 2007
382
6 232
Работаю - по всей видимости пошустрей 2007-го - те файлы которые панорамировались как слайдшоу в 2007, в 2008 с легкостью и плавно... В 3d тоже порезвей... Очень красиво 3d прям в вьювпорте шейдинг с падающими тенями, оно понятно, что карточку бы производственного класа а-ля квадру, но все равно эффектно...
venz
19 Мая 2007
382
6 232
Из кординальных нововведений: реагирующие на масштаб модели -выноски, размеры, текст, блоки. Т.е. при изменении масштаба (...1:50, 1:100, 1:200...) эти элементы соответственно уменьшаются или увеличиваются дабы оставаться читабельными - очень полезная долгожданная весчь!)
yury
29 Ноября 2007
35
710
, Руковожу мышкой,
Здравствуйте товарищи!
Вот надумал посмотреть что такое ADT и насколько он лучше автокада.
Мысь такая пришла потому, что у нас в конторе все чертят как попало - кто в натуральном масштабе, кто в масштабе листа, все чертежи в одном файле (что приводит к неподьемным тормозючим 7-8 мб файлам)..., мне (конструктору) приходится разгребаться со слоями и масштабами архитекторов которые часто не чертят а рисуют... вобщем беспорядок полнейший.
Да и глюки СПДСа уже замучали.
Вопрос в том, есть ли в ADT инструменты систематизирующие проект, автоматизирующие работу по оформлению чертежа и составлению спецификаций.
Поможет ли ADT автоматизизированно получать спецификации по сборным элементам (КЖ) и например стропильным системам.
И еще:
где добыть библиотеки для ADT под наши нормы
Подскажите и направьте где копать
venz
29 Ноября 2007
35
710
Значицца, опять-таки, нет такого - скачал и тебе щастье. Если грамотно начинать проект то в АА у нас объект делится не только на этажи, но и скажем так "области" и еще и на разделы по смежникам - итого "4d" - в идеале после архитектора+конструктора (а может и параллельно) проект открывается в Билдинг Систем (сейчас другое название) где прям в объеме кондиционерщики ведут патрубки в реале меняя сечения и профили трубы (переходники генерятся автоматом), причем машина сигнализирует о коллизиях (физических пересечениях в пространстве трубопроводов) и ваших нарушениях настроенных правил (слишком маленький радиус закругления, их слишком острый угол и т.п.) - после этого генерятся их принципиальные схемы в изометрии и так далее по всем смежникам. Вертикальщики берут цифровую модель скаченную с цифровых теодолитов геодезистами, садят объект на местность и автоматом генерится план земельных масс и т.п. Если конструкции строить, подрезать правильно - то вам и виды (которые иногда в случае криволинейных форм мысленно не вообразишь ), разрезы и спецификации - причем не мертвые, динамичные. Мне было надо я сделал себе шаблон - где создаются слои для определенных объектов - например при вставке унитаза создается слой Сантехника и этот унитаз вставляется в этот слой и т.п. Сделал экспликацию которая меняет значения и сортируется в зависимости от изменений помещений. Ну а такого, что б скачать и зарабатывать 5 кликами не встречал. Шаблоном могу поделиться...
ps: 7метровые файлы получаютя из-за того что 20 стилей текста и 13 неиспользуется, 70 неиспользующихся блоков в четверть чертежа и 11 размерных стилей - чистить файлы надо пьюржем
yury
29 Ноября 2007
35
710
, Руковожу мышкой,
как говорил классик 90х "я не халавщик, я партнер"
. Согласитесь, глупо самому делать работу которую уже научили делать компьютер. например резать разрезы или считать спецификации. За шаблон спасибо, если в нете не найду ничего к Вам обращусь.
Если я правильно понял, то вы venz ADT пользуете. Реально в жизни описанная вами схема работы встречается?
Вы в довесок к ADT CS СПДС ом пользуетесь? или всё оформление средствами самого АДТ.
вообще тут я вижу такой + : это тот же автокад и те же методы работы, но меня беспокоит то, что найдя решение допустим одной проблемы можно приобрести 5 других.
ну я не спец крутой, но и не совсем дикарь. про пурдж знаю, но так трудно других заставлять работать ПРАВИЛЬНО не будучи их начальником...
venz
29 Ноября 2007
35
710
"Ну а такого, что б скачать и зарабатывать 5 кликами не встречал" - это я не в отношении вас, а в отношении какой бы то нибыло настроенной системы настроек для конструктора на основе АА. Я делал все сам изменяя и рихтуя элементы буржуйского дизайна. СПДС не пользую т.к. это зло. Все есть в АА и все очень гибко и легко настраивается. Но если вы сделаете свой шаблон + свою панель инструментов - "клепать" проекты можно буквально. То что я описал есть у них. У нас Аутокад 2006.
Добрый Модератор
30 Ноября 2007
141
2 609
, Руководитель проекта,
присоединяюсь и хлопаю в ладоши
yury
30 Ноября 2007
35
710
, Руковожу мышкой,
да, спдс ГЛЮЧНЫЙ, нужно носить шрифты вместе с чертежами, но оформление - там все удобно и не нужно ничего писать дополнительно. Чем вы пользутесь в дополнение к автогаду 2006?
venz
30 Ноября 2007
35
710
Это я так неясно описал ситуацию общей системы проектирования в США скажем и у нас. У них - полная связка от начала до конца - ЛэндДесктоп-Архитектур-Билдинг Систем и т.п. У нас верх желаний Аутокад 2006. Я лично работаю В АА2008 - тем более в макс можно линковать. А если хатки Скетчап, или сразу в максе.
yury
30 Ноября 2007
35
710
, Руковожу мышкой,
мда... во такую цепочку я и хотел выстроить.
Смотрел Аллплан - сложно и чуждо, Ревит - сыро, негибко, не под наши нормы, но для архитектора мож. пошло бы. Вернуля к тому с чего начал -Автокад, но уже в шкуре ADT (AA). Попробую его освоить и соблазнить на это архитекторов.
venz
30 Ноября 2007
35
710
Все правильно. На 100% согласен. Постараюсь на днях выложить свой шаблон - может пригодится. А вообще, задавайте вопросы - чем смогу ....
ArhiGraf
30 Декабря 2007
35
710
венз! скинь шаблон для интереса - давно хотел посмотреть продвинутую работу, сам пока только в 2007 недавно начал работать, увы. но судя по твоим постам - пора уже аа08 ставить. а вообще в группе у нас одичали в смысле знаний и широты души(увы). привет из гродно и сновым годом!
RoMaN
04 Января 2008
14
Люди скиньте ссылку где можно скачать ADT 2008 (RUS)
wixa
10 Февраля 2008
14
Здравствуйте. Вот только начал работать с AutoCAD Architecture 2008.... в предидущих версиях не работал, работал только в стандартных автокадах.... Подскажите пожалуйста есть ли справочник по AutoCAD Architecture 2008 на русском языке, и где его можно скачать?
Заранее спасибо...
С уважением, Константин
Wir_Mag
10 Февраля 2008
423
4 339
http://dwg.ru/dnl/2758
вот это вроде русское
Wir_Mag
10 Февраля 2008
423
4 339
в личке еще кое что
wixa
10 Февраля 2008
423
4 339
Спасибо Большое... это конечно пригодится, но мне нужен справочник именно для версии Architecture 2008 ....
Wir_Mag
11 Февраля 2008
423
4 339
слушай, набери в гугле вот эту фразу "руководство по autocad Architecture 2008 на русском языке" тебе много чего интересного выдаст, там все найдешь, я только что проверил сам лично
RoMaN
15 Апреля 2008
14
Venz скинь шаблон посмотреть - интересно.
moimir
25 Апреля 2008
14
Помогите!!!!!!!!!
Работаю с трехмерными объектами (раньше как-то только чертежи 2D приходилось). Когда ставлю на план трехмерные объекты (мебель расставляю), все они вставляются на разной высоте, и я потом на виде спереди передвигаю их, задавая каждому объекту координаты. Наверняка ведь есть нормальный способ работы.
? КАК СДЕЛАТЬ, ЧТО БЫ ВСЕ ТРЕХМЕРНЫЕ ОБЪЕКТЫ ВСТАВЛЯЛИСЬ НА ОДНОЙ ВЫСОТЕ?
Ex-Inferno
01 Мая 2008
29
463
, cтаж: 23 лет
Не знаю, как обстоит дело с интеграцией СПДС с АА2008, а в ADT 2007 я избежал глюков СПДС путем подгрузки оного в качестве приложения.
Ex-Inferno
01 Мая 2008
29
463
, cтаж: 23 лет
Цитата moimir:
Помогите!!!!!!!!!
Внизу экрана есть меню "ПСК смещение по Z". Нужно, что бы там была установлена одна и та же отметка. Если проблема не в этом, то нужно корректировать точки вставки многовидовый блоков
Wir_Mag
01 Мая 2008
423
4 339
у меня с СПДС 4 никаких проблем никогда не было и я очень доволен им...
Программы для проектирования (в разделе 641 тем)
